Home Forums Products Stompboxes Start up problem Reply To: Start up problem
#123585
    This means that the left-hand foot switch is stuck down or broken. Have a look at it and see if you can free it, otherwise it is damaged and will need repair.
    You can change the switch yourself if the pedal is out of warranty and you are handy, or you can send it in. Either way – support@eventide.com
