Home Forums Products Stompboxes MODFACTOR Broken? Reply To: MODFACTOR Broken?
#123611
    It does sound like you have a power supply problem. But, if you have tried two supplies, and the display just shows a vertical line on its left, this would suggest that the failure during the update damaged the unit.
    If you can get it into update mode manually by holding down the center switch at powerup, all is OK and you should run the update again. If you can't, it will need to come in for service.
