Home › Forums › Products › Stompboxes › Timefactor MIDI set up/GCX hookup › Reply To: Timefactor MIDI set up/GCX hookup
July 9, 2012 at 8:38 pm
#123637
The best suggestion I can think of is to connect the out of one of the loops on the GCX to the expansion pedal in of the TF. You would then go into the TF and program that button for time tempo. then you would set up an instant access on the Ground control. Once that is all set-up you should be able to control tap tempo from your ground control through the GCX.
