Home › Forums › Products › Stompboxes › Pitchfactor buttons not working when output cable is connected! › Reply To: Pitchfactor buttons not working when output cable is connected!
Serial no PF-06045 if that helps, it seems to be pretty much dead. Its only 1y and 4 months old, and even though its outside of limited manufactor warranty, i believe its still covered under the UK fair use warranty, as this item is very young, has not been used very much and is in great condition and it seems like it has broken becuase of a mechanical failure inside. As i have stated, system is fine when no output cable is connected, but freezes entirely when cable is connected to either output jack. Even the external switch doesnt work then!
Any help from eventide would be appreciated.
