Home › Forums › Products › Stompboxes › Can I make the time factor get that sweeping effect when adjusting the delay rate? › Reply To: Can I make the time factor get that sweeping effect when adjusting the delay rate?
August 6, 2012 at 5:16 pm
#123709
Tried the Vintage and tape delay. They did get closer to what I was looking for. But they still seem to have a weird phaser effect in the feedback instead of being that crisp ring I'm looking for. Also the vintage delay seemed to have a lag on it. When I moved the expression pedal to adjust the rate it would sweep after I shifted the pedal and not while I was shifting it.
Thanks for your reply, if this is the case I will probably have to return this pedal 🙁
