Home › Forums › Products › Stompboxes › Looper dry mix is a whisper › Reply To: Looper dry mix is a whisper
August 10, 2012 at 2:11 pm
#123716
What bypass type are you using? Also, double-check your setup; I know it sounds stupid, but I was playing with FilterPong last weekend and wasn't getting any dry signal, only to realize that I had connected my audio output to Output 2 of the TImeFactor (I run a mono setup at home).
