Home › Forums › Products › Stompboxes › Time Factor & Adrenalinn 3 easy midi setup? › Reply To: Time Factor & Adrenalinn 3 easy midi setup?
August 14, 2012 at 8:48 pm
#123730
TimeFactor has extensive MIDI features which should allow you to do what you are asking about.
You
can assign MIDI continuous controllers to alter Expression Pedal
values and knob parameter values. These are set in the RCV Control menu
of the MIDI section in System Mode.
To link up Presets to your MIDI controller you can change the RCV MAP so that specific Program Change numbers will call up the Presets that you wish.
Do you know which MIDI Continuous Contollers are being sent by the Adrenalinn?
