Home › Forums › Products › Stompboxes › Is this possible via midi with the Timefactor? › Reply To: Is this possible via midi with the Timefactor?
August 29, 2012 at 2:12 pm
#123765
I am having the same problem… But the order of the pedals that you have, is reversed in my set up. I use a Behringer FCB 1010 controller between both petals and select presets together so they move like one unit, but I have tried syncing the clock to be able to tap on only one of the units, and cannot get it to work. I think tapping and clock would be better on the Time Factor, but the adrenaline will also be fine if I can get it to work.
