Home › Forums › Products › Stompboxes › Phase issues with Eventide Space during patch changes › Reply To: Phase issues with Eventide Space during patch changes
#123789
wedelich
    Hi ccl117,
    Is your Space running the latest firmware? Should be 4.0.0 Devil.  You can check in the system menu, under UTILITY SW VERSION
    I tried to reproduce this with on a Space by itself (with Killdry on) and could not reproduce it.  Does it occur on all presets or just the two you mentioned?  Does it occur when you just run through the Space alone or only when the Space is in the line mixer configuration with/without the Timeline?  We'll do our best to help you narrow it down.   If there are certain presets where its obviously worse, would you mind sending those our way?
    Thanks
