Home › Forums › Products › Stompboxes › space freeze function help needed › Reply To: space freeze function help needed
September 7, 2012 at 4:15 pm
#123799
Hi agregoria,
To me, it sounds like you're trying to use freeze by switching in to freeze mode, and then playing a note. Freeze will cause the signal in the reverberators to recirculate infinitely, but if there is not enough signal in there, it will recirculate with very low energy. Make sure you feed enough "note" into the reverberators and then Freeze to catch that immediate energy.
