Home › Forums › Products › Stompboxes › Blank Backplate for Factors › Reply To: Blank Backplate for Factors
#123852
exhausted
    Bike chain links are the solution that was mentioned.  If you wanted to attach them more permanently to the board.
    With regard to velcro, because it won't stick well to the rubber on the bottom, I found that putting duct tape on the rubber and then sticking the velcro to that worked fine.  Even that industrial grade velcro won't adhere to the rubber used.
