Home › Forums › Products › Stompboxes › space freeze function help needed › Reply To: space freeze function help needed
#123862
Daniel
    I'm having a little trouble understanding the SPACE Freeze function as well. I've been told I need to be in Play Mode, not Bank, to get the Freeze to work. Is that correct? Infinite seems to function in Bank. Do I need to use Play for Freeze? Hot Switch to access it? Mix at/near 100%? Play a note/chord, then hit the Hot Switch? Sorry, I am somewhat tech-challenged, and without direct instructions (in the manual), I can't always figure things out.
    Thank you,
    dan
