Home › Forums › Products › Stompboxes › Blank Backplate for Factors › Reply To: Blank Backplate for Factors
October 7, 2012 at 11:01 am
#123876
http://www.johnnyshredfreak.com/ sells the bike chain fixings (I have no connection to them)
personally I take a blunt table knife and carefully place it under a corner of the rubber …. Gently pry the rubber away from the base…. It will come off in one piece and cleanly…. And can easily be re-applied… Does not mess anything up.
i understand if you do not want to try it, but I have successfully done this with 5 factor pedals am you would not know if you saw them when I put them back.
i then use Velcro on the base, but don't cover the label… Again you can peal it off cleanly.
