Home Forums Products Stompboxes Using Moog Multi-Pedal to make Preset/Bank changes of Space and TimeFactor Reply To: Using Moog Multi-Pedal to make Preset/Bank changes of Space and TimeFactor
#123888
Imerkat
    Hello!!
    I have the Moog Multi-Pedal (MP-201). and yes you can but you're going to want to send PC (program change) messages for preset changes. You don't even need to Map the PC messages or have the same channel in the eventides. The Moog can be programmed to send PC message on whatever channel and preset you want to pull. You can also assign CC messages to bypass the pedal as soon as you load a preset in the Moog and toggle it on/off as needed. The Cool thing about the Moog is that you can use the CV outputs to control the Exp. Pedal in the Eventides. I wouldn't recommend the Moog Pedal as a midi controller  if you are trying to control more then 2 midi devices. It works best as a midi to CV mediator or an LFO generator.
