Home › Forums › Products › Stompboxes › switching between BPM and ms, no catchup › Reply To: switching between BPM and ms, no catchup
October 17, 2012 at 2:53 pm
#123891
What are you trying to accomplish by doing this? It sounds like you want to use Tap to set the delay time, and then be able to adjust it further with the delay time knob. When you adjust a parameter, while the display still shows the parameter value, you can use the encoder to further edit a parameter, whether it's the Delay Time knob parameter or the Tap Tempo parameter.
