Home › Forums › Products › Stompboxes › switching between BPM and ms, no catchup › Reply To: switching between BPM and ms, no catchup
#123892
What are you trying to accomplish by doing this? It sounds like you are trying to Tap to set the delay time and adjust it further with the Delay Time parameter knob. You can always change parameters with the encoder, while the display shows the parameter value. So after you hit the Tap button you can use the encoder to adjust the value while the display still show the tempo in BPM or MS.
