Home Forums Products Stompboxes EBJr Expression with Pitchfactor: Range not accurate Reply To: EBJr Expression with Pitchfactor: Range not accurate
#123900
gregLhorton
    Thanks for the quick reply.  I have tried to unplug the EBVPJr then re-plug it in, to re-calibrate.  If I move all the way to the toe position the PF does say it's at 100.  But when I back off towards the heel position it stays at 100 until I am about 30-40% towards the heel position.
    I am not around the volume pedal now but I will make sure it's a 25k version.  I am not positive that it is.  Would this behavior be expected if it was not 25k?
    Thanks
    Greg
