Home › Forums › Products › Stompboxes › Modfactor and Timefactor, expression pedal passing MIDI CC to second unit, min and max values › Reply To: Modfactor and Timefactor, expression pedal passing MIDI CC to second unit, min and max values
#123931
rabiddiabetic13
    I have my Modfactor expression pedal setup to control Pitchfactor via midi.  I can program any parameter knob on the Pitchfactor by going to heel position and then turning parameter knob on Pitchfactor to set min value, then go to toe position and set max value on parameter knob.  Works fine.  You have to do a save on the Pitchfactor for it to stay programmed after preset change.  Can't see why it would be any different trying to control  the Timefactor the same way.
    hope that helps
    A
