Home Forums Products Rackmount H8000FW and firewire Reply To: H8000FW and firewire
#123946
    The second port is similar to the first, so essentially the two ports you mention in the second paragraph.
    You can use one of these ports to relay the other (don' t know why you would). We don't have figure for the latency between the ports – I would guess that it would only be a small number of samples.
