Home Forums Products Vsig and Preset Development Pitch Arepggiator Help Reply To: Pitch Arepggiator Help
#123988
    Don't see anything to make it sustain – if you stop playing it will die away. If you want it to continue after you stop playing you should add some feedback to the shifter, by adding another mixer before the shifter to mix some of the output with the input.
    Note that using the diatonic shifter means you must play in the right key,  in your example C Major.
