Home Forums Products Stompboxes Dynaverb Presets & the Feedback Feature Reply To: Dynaverb Presets & the Feedback Feature
#124004
wedelich
    Hi BarneyBrown,
    1.  Personally I mostly use DynaVerb for Swells (Dynamic Reversal) and for doing stuff like making a room sound bigger the harder you play.
    2.  There are two classic compressor topologies.  A Feedforward compressor gets level directly off the input signal and uses that to control the Automatic Gain.  A Feedback compressor  actually uses the level after the Automatic Gain to control the Automatic Gain.  So, we took it a step further on the contour knob by allowing you to mix between these two signals.  Does that make sense?  It can be a sublte effect in Omnipresor only mode.   It's less subtle as sidechain mixer in the Reverb Mode.
