Home › Forums › Products › Stompboxes › Help needed with PF; using footswitch for tap tempo › Reply To: Help needed with PF; using footswitch for tap tempo
November 30, 2012 at 6:46 pm
#124045
The footswitch inputs can only change the settings listed on page 47 of the PitchFactor manual, one of which is the same tap tempo as the right footswitch on the PitchFactor. If the tap tempo footswitch is not what you are looking for, could you explain more about what you are trying to do?
