Home Forums Products Stompboxes New Factor and Space Upgrades? Reply To: New Factor and Space Upgrades?
#124092
Thanks Alan,
Only problem is I use the factors in a wet/dry rig with killdry engaged. If I select no delay for either A or B (a CC level of zero to knob 2 or 3) with the Timefactor, it passes a dry signal which doesn't play well in a wet/dry rig (phasing). If no delay on A or B meant mute when Killdry was engaged, I'd take it, but then I'd lose the trail off's.
Chris….
