Home Forums Products Stompboxes Timefactor – MIDI issues Reply To: Timefactor – MIDI issues
#124094
It's quite likely that your problem is unrelated to your TF and is caused by some of the other equipment.
To find out, connect the GCP directly to the TF and see if you still have the same problem. If you do – read the manual many times, paying particular attention to MIDI Learn mode.
