Home Forums Products Stompboxes Timefactor – MIDI issues Reply To: Timefactor – MIDI issues
#124096
Thanks Guys,
I got it sorted and everything is working perfectly!
I started with the GCP direct to the TF and it worked perfectly; therfore the issue had to be with the M9 not passing messages through. Instead of messing with the M9, I set the TF to through and reversed their order in the MIDI chain GCP –> PS1 –> PS2 –>TF –> M9
I read some older posts trying to find the solution and there were several complaints that the TF couldn't be bypassed using Program Change messages. Under RCV MAP I found 125>BYP and it works perfectly when called.
I have also set one of the IA buttons to BYP so I can bypass the delay within a preset.
Very cool rig now that MIDI is working. The Timefactor is an incredible delay!
