Home › Forums › Products › Stompboxes › Midi Help w/ 2 Factors › Reply To: Midi Help w/ 2 Factors
December 19, 2012 at 4:02 pm
#124113
Not quite sure how, but it sounds like you have corrupted the presets in some way. I would suggest that you reinitialize the unit to return to factory defaults and see if the problem is still there.
Hopefully you saved your original presets on FactorLib before changing them, in which case you can send them back. You will probably NOT want to repeat whatever changes you made.
