Home › Forums › Products › Stompboxes › Time Factor in Mesa Boogie Triple Rec Effects Loop – Please Help › Reply To: Time Factor in Mesa Boogie Triple Rec Effects Loop – Please Help
January 6, 2013 at 12:03 pm
#124154
Ok, have a play with the switches, they will affect the level if the buffer settings are not set to relay (true bypass)
I think the default settings for the TimeFactor is to be buffered.
Try the switches first, given that the other pedals are guitar pedals you might need to set the TimeFactor in as "Amp" and the output as "Line"… Just try the various combinations of this switches.
