Home Forums Products Stompboxes Which setting adds reverb? Reply To: Which setting adds reverb?
#124160
ndeshpande
    TimeFactor isn't really a reverb, none of the algorithms are reverb algorithms. Multitap, with certain settings, can get you in the ballpark though; I like mine with delays A+B set to 10, then I set delay A to something shorter (maybe around 250-300 ms) and delay B to something longer (around 800-1200 ms), then feedback around 80 and slur and spread at full. Play around with the taper to see where you like it, and cranking the mix knob to 70 or higher will get you close.
    Again, keep in mind that TimeFactor is not a reverb unit.
