Home Forums Products Stompboxes modfactor and pedal switcher ( no aux switcher) Reply To: modfactor and pedal switcher ( no aux switcher)
#124174
ndeshpande
So you're just trying to put the ModFactor in a bypass loop? That'll work, but keep in mind that the sound will only be effected when the bypass loop is engaged, and depending on the looper you may be limited to mono in/out. Essentially, you're restricted to the limitations of the bypass loop.
