Home › Forums › Products › Stompboxes › TimeFactor Bypass Latency › Reply To: TimeFactor Bypass Latency
January 16, 2013 at 5:47 pm
#124186
You could try using TimeFactor's Killdry feature. It is a Bypass Mode designed for use with effects loops. With Killdry ON, Bypassing TimeFactor mutes the output, so you can leave the amp's effects loop ON the whole time.
