Home Forums Products Stompboxes Timefactor: All lights blinking Reply To: Timefactor: All lights blinking
#124248
    This is not a good thing. Sorry.
    First make sure you are using the supplied power supply. Then, check the power lead and socket for damage, by "wiggling" each part to see if this causes the problem.
    If the above does not help, it is probably a hardware issue, and you should contact your dealer, or support@eventide.com
