Home Forums Products Rackmount H8000 won’t start Reply To: H8000 won’t start
#124254
    Probably after the "problem with setup" message, it will invite you to press another key for more info. You should do this.
    Either way, the first thing to try is a CLEAR SETUP, followed if necessary by a CLEAR INTERNAL. See UM for info.
