Home Forums Products Stompboxes TAP tempo not syncing Reply To: TAP tempo not syncing
#124290
Thanks Brock, that helped a lot!  With the master output set to thru it syncs with space after a hard reset and new software.  Although, with the mobius inline all pc transmission was blocked to it from the XMT function of the Timefactor.
I tried the universal tap tempo switch with the Behringer foot controller and it worked ok except that there seems to be some latency along the chain so each pedal in the chain is anywhere from 3-30 ms out of sync and some don't sync at all depending on whether they are in BPM or ms… weird but I guess I'll take it and see what I can do with it nonetheless.  At least I know the Space and Timefactor work properly now.
