Home Forums Products Stompboxes Eventide Space goes Crazy Reply To: Eventide Space goes Crazy
#124295
    Make sure you are using the Eventide Power Supply – my guess is that the power supply is bad.
    If the Power Supply is OK, try "restore factory system settings." If this fails, you should go to your dealer, or support@eventide.com.
    You will find Warranty Information at the back of the User Manual.
