Home Forums Products Stompboxes Aux Switch -> ACT Reply To: Aux Switch -> ACT
#124298
luedmo
    +1 to an ACT function as an AUX switch option, but…
    The "ACT" function that exists in the MIDI > RCV CC menu (where both ACT and TOG are options) does not latch. That's means when you set up an AUX switch – TIP, Ring or T&R – in XMT CC menu and over as CC you trigger ACT in another pedal when you take your foot off.. it is Bypassed! Even more weird, if the preset in the 2nd pedal was ON, pressing the Aux switch will turn it OFF when you take your foot off.
    Not quite sure how this is meant to work. Perhaps someone can explain how this works in a good setup. Just scratching the surface of MIDI here, I would say what we need is a new function that is similar to ACT but is different in that it
