Home › Forums › Products › Stompboxes › Change TimeFactor parameter values via MIDI › Reply To: Change TimeFactor parameter values via MIDI
March 7, 2013 at 9:27 pm
#124355
If you are not using the Expression Pedal, you could plug a switch into the pedal socket and treat it as a pedal. The pedal settings ARE saved with the preset, rather than being global.
