Home › Forums › Products › Stompboxes › Timefactor: Can you use Repeat function from Play mode while in the Bank mode? › Reply To: Timefactor: Can you use Repeat function from Play mode while in the Bank mode?
March 11, 2013 at 3:35 pm
#124362
You will probably need an AUX SWITCH or a MIDI controller to use the RPT function in preset mode. See the UM for more info.
