Home Forums Products Stompboxes Will Space send aux pedal as midi CC? Reply To: Will Space send aux pedal as midi CC?
#124363
    ianstephenson:
    I'd like to use the aux pedals (tip, ring, tip&ring pedals) to control another midi device by sending CC messages
    You can.
    ianstephenson:
    I'd also like to assign the freeze function of the space to one of it's aux pedals
    Freeze is activated by turning Feedback or Decay as appropriate to the maximum. You can do this with an AUX switch.
    ianstephenson:
    Useful too would be the ability to control the volume of the freeze sound using an attached expression pedal.
    If you use the pedal to control the wet/dry MIX this will do it for you,
    Sounds like there is some User Manual reading in your future !!
