Reply To: Timefactor: Can you use Repeat function from Play mode while in the Bank mode?
Home Forums Products Stompboxes Timefactor: Can you use Repeat function from Play mode while in the Bank mode? Reply To: Timefactor: Can you use Repeat function from Play mode while in the Bank mode?
#124369
mr. limbic
Yes you can, but you will need an auxiliary controller. I use the Digitech FS3. It is a small 3 button footswitch that you can assign any number of parameters on the TF to. I have my 3 buttons setup as follows: Far right button is bank up, middle button is bank down, and left button is the hold function+play mode switch. I have both set like this bc when I engage the hold function it will automatically switch my pedal to play mode and then when I am done with the hold I press it again, the hold releases and it auto switches back to bank mode. THis works really well for me, let me know if you need any other help. I highly recommend an aux switch like the digitech to make it more usable live.
