Home › Forums › Products › Stompboxes › Controlling pitchfactor using midi ccs – footswitch left and middle › Reply To: Controlling pitchfactor using midi ccs – footswitch left and middle
#124377
    Quote:
    Is it even possible to use midi to select bank presets 1 and 2?
    Make sure that the PitchFactor itself is in Play mode.
    The FS1, FS2, and FS3 destinations control the footswitch options in the opposite mode of what the pedal is currently set to.  In Play mode, your CC3 message should alternate ACTIVE and BYPASS on 'preset 1', and the same for CC4 on the 'preset 2'.
    The other option is to select the presets directly using Program Change messages.  PC 99 would select PitchFactor preset 50:1; PC 100 selects 50:2, etc.
