Home Forums Products Rackmount self modulating eclipse Reply To: self modulating eclipse
#124439
    Pretty much any parameter on an Eclipse can be modulated. My guess is that you have some modulation sources connected without knowing it. You could try either a "clear internal memory" UM p.56, or look at each parameter that is being modulated in turn and check its modulation source (see UM p.40-46).
