Home Forums Products Rackmount H8000 Startup Error Reply To: H8000 Startup Error
#124456
    The message suggests that it is a hardware problem associated with U106, which is a large socketed chip to the center front of the motherboard.If you are handy, you could try "wiggling" this in its socket, otherwise it probably needs service.
    If this started immediately after a software update, you could try repeating the update.
