Home Forums Products Stompboxes UPDATE FALIED, EVENTIDE TIME FACTOR NO ARRANCA! Reply To: UPDATE FALIED, EVENTIDE TIME FACTOR NO ARRANCA!
#124459
    It sounds like your update has failed, leaving the unit in a bad state. If you can get it back into UPDATE mode, you should try the update again. If not, the unit has to go for service, ideally to a local dealer, but if not, back to us in the US.
    If the last is necessary, contact support@eventide.com
