Home › Forums › Products › Rackmount › two questions related to Orville › Reply To: two questions related to Orville
May 14, 2013 at 2:50 pm
#124489
The HC error means that one of the dsps was overloaded or shut down. It may be associated with a bad digital input or certain presets. Either way, no need to worry unless it happens repeatedly.
The Orville can run quite hot, which may cause the effect you describe. Make sure that it has good ventilation. Or it may be something else entirely ..
