Home › Forums › Products › Rackmount › Wordclock Input BNC connector replacement? › Reply To: Wordclock Input BNC connector replacement?
June 28, 2013 at 3:36 pm
#124592
Depends on how handy you are. The metal part can't be changed by itself, because it is part of a double socket. You would have to take the unit apart and and solder the part from the motherboard and replace it. Probably a job for a dealer, but if you want to try it yourself, support@eventide.com should be able to supply the part as you probably cannot get it locally..
