Home › Forums › Products › Stompboxes › Pitchfactor bypass/active question › Reply To: Pitchfactor bypass/active question
July 9, 2013 at 4:26 pm
#124619
There is a short loading time when going from Bypass to a new Preset of a different Algorithm. You may find that going to a Preset of the same Algorithm has less loading time.
If you're coming from Bypass you may need to pre-load the preset you want and then bypass until you're ready to use it.
-Alan
