Reply To: Eventide Time Factor with RJM Line MIXER and Expression pedal
Home Forums Products Stompboxes Eventide Time Factor with RJM Line MIXER and Expression pedal Reply To: Eventide Time Factor with RJM Line MIXER and Expression pedal
#124621
achaput
Hi Euripides,
In a parallel effects loop, Killdry would be an appropriate setting. You can assign an expression pedal to control MIX on a per-preset basis. There is also a Global MIX option that keeps MIX values the same for every Preset.
-Alan
