Home › Forums › Products › Stompboxes › Help, think my Space is broken › Reply To: Help, think my Space is broken
July 12, 2013 at 3:53 pm
#124628
The fact that it was triggered by a power problem suggests that your power supply or its connections were damaged – you should try and borrow another one and see if it makes the difference. If it does, you can get one from the Eventide Web Store.
Otherwise, try a "Restore Factory Settings" as described in the UM.
If both the above fail, support@eventide.com
