Home Forums Products Stompboxes Eventide Space power supply questions Reply To: Eventide Space power supply questions
#124643
    We can only recommend the power units we supply, because of the amount of testing required.
    This one looks like it is bigger than you need. Note also that if it is unregulated, it may produce a high voltage that can damage the unit. Also, if it is a switcher, it may produce audio noise. These are just some of the problems you may encounter. Or not.
