Home Forums Products Stompboxes How to mount an H9 to a pedalboard? Reply To: How to mount an H9 to a pedalboard?
#124671
achaput
    The rubber feet on the H9 are securely fastened using strong industrial adhesive. I do not blame you for hesitating to remove them. If you change your mind, you should NOT use any type of force in the direction of your face or body. You should wear eye protection. A flathead screwdriver could be used to pry them off, as could a small pair of pliers. Please be careful.
    Alan
